b230ft oil
Old Jun 20, 2010 | 08:21 AM
chrisk's Avatar
Default b230ft oil
My 1995 940 tubo with 90,000 miles is blowing oil and smoke. I changed the PCV box hoping that would help but the smoke is just as bad. I see oil coming out after turbo where it connects to exhaust manifold and exhust down pipe.
There also is an oil leak at the front corner of the head gasket.
The smoke started about thee months ago and got progressivly worse.
Can anyone tell me what the next diagnostic test would be?
Old Jun 20, 2010 | 05:05 PM
swiftjustice44's Avatar
Well, the seals in the turbo do go bad and will cause oil burning. My question would first be, what viscosity oil are you using?
Old Jun 20, 2010 | 10:55 PM
tedv's Avatar
Chances are you need a turbo rebuild... Even the thinnest oil shouldn't escape through those seals...
Old Jun 21, 2010 | 06:19 AM
Typhoon's Avatar
I agree with the turbo too. Centre sections are fairly cheap these days, you should not see any oil leaking from the turbo anywhere. Oil doing this is a sign of some sort of turbo related failure, no matter where it is coming from.
Regards, Andrew.
rooster11
Jun 30, 2011 12:33 PM
boostedbrick
Feb 23, 2006 01:30 PM
ezwilly
Sep 2, 2005 09:36 PM
Gogats
Aug 30, 2005 10:02 PM
Desperado
Apr 10, 2005 02:36 PM
