barely starts then stalls
Old Jun 30, 2008 | 07:37 PM
240tank's Avatar
Default barely starts then stalls
my 91 240 has been running fine but this morning it was hard to start. it turned over for a while then finally started but as soon as i hit the gas it would stall.
Old Jul 1, 2008 | 04:35 PM
obaloney's Avatar
Default RE: barely starts then stalls
I recommendchecking the air mass meter located just behind the air filter housing. The symptom you describe is a classic air meter problem. If you know someone with a 240 that has the same air meter, try swapping theirs for yours, it takes just a few minutes to do. If your car starts, that's the problem. If you do have to replace the air meter, you can buy a rebuilt, which will cost $200-plus.
flatbrick
Apr 5, 2013 12:01 AM
jethrobodean
Oct 22, 2011 07:48 PM
mowntnbkr
Oct 19, 2011 07:15 AM
iluvmyslut
Jun 16, 2011 07:51 PM
Pyrate
Apr 5, 2010 01:25 PM
