Battery question..
Old May 8, 2006 | 08:48 PM
azalea's Avatar
Default Battery question..
Recently bought a 1988 240 DL.. the battery WILL NOT stay charged.
1st. Fully charged battery would be dead in 24 hrs... groundwire on alternator disconnected. Spoke to the seller, "Hasn't worked right since we had the new radio put in"
2nd. Fully charged battery would be dead in 2-3 days. Miswired fuse box.
Now.. radio doesn't work... a fully charged battery still goes dead in a couple of days. It lasts longer if I drive short distances, If I drive to work.. 45 mins.. it drains the battery. The alternator was tested and is OK. Could it be the cables? Any help would be appreciated.
Old May 8, 2006 | 08:54 PM
tupapison's Avatar
Default RE: Battery question..
You sure the wiring and everything in the alternator is working? Because my car had the same problem and i got the alternator fixed and it worked
Old May 8, 2006 | 08:55 PM
azalea's Avatar
Well, had it tested and they said Yep.. it's fine!
Old May 8, 2006 | 09:20 PM
azalea's Avatar
also wanted to add... this morning battery read 12, drove to work.. it read 12.2 . It sat all day, started once, then would not restart, battery read 11.5
Old May 8, 2006 | 09:38 PM
Make sure the Glove box light isn't staying on.
You need to connect a Volt meter inline with the Battery and see how many Amps are being pulled.
Old May 8, 2006 | 10:19 PM
tupapison's Avatar
I THINK that the normal amp is 13 or 14?
Old May 8, 2006 | 10:33 PM
When you test for Amp draw it is supposed to be between .025 and .050.
Old May 16, 2006 | 03:16 PM
cbevis's Avatar
who installed the radio?
Jeffers
Nov 21, 2012 06:50 PM
mrcanon918
Sep 24, 2009 12:35 PM
chrisbridges
Sep 4, 2009 07:28 AM
greydiesel
Aug 16, 2009 05:18 PM
cmercon
Feb 2, 2009 02:15 AM
