Brake Booster replacement
Old Aug 27, 2017 | 02:44 PM
Rachael Bowman's Avatar
Default Brake Booster replacement
Replaced booster in 1993 940 turbo wagon. Pedal is hard now, barely depresses. Brakes eventually build pressure, stick and car will barely move. Tried adjusting the rod..no help.
Any suggestions.
Old Sep 3, 2017 | 09:58 AM
madman77's Avatar
Sounds like the check valve isn't working. When you start your car with your foot on the brake ,the pedal should move down a little, if it doesn't then it's the valve not letting vacuum to the booster.
tech
Jul 28, 2020 03:04 PM
tech
Apr 5, 2017 09:57 PM
tech
Jul 11, 2016 03:06 AM
snpklinefelter
Dec 22, 2009 06:26 AM
jurteaga
Jan 6, 2006 12:09 AM
