brake lights
I just purchased a 1990 240
now, the brake lights will not work, fuse was blown any ideas, all bulbs are good |
RE: brake lights
Make sure the Fuse box is very clean and try again.If it blows again the I would look at the switch first if that is fine then look at the printed circuit board for the taillights.
RE: brake lights
i will try the switch
do i need to sand the fuse holders all the other lights work. tail, turn, reverse |
RE: brake lights
Clean it up any ways and put some dielectric grease on the connections.
Check for power to the switch.Then check the other side with the pedal pushed down. |
RE: brake lights
Yes check the switch at the brake pedal assmb. I've personally had to fix mine on my junk Honda several times (Volvo does have a superior design) But the switch can always go bad, that sometimes happens. I agree check the fuse also to verify that it does indeed have a good connection.
RE: brake lights
Thanks for your help, it was the brake light switch
and i repalced all the fuse's |
RE: brake lights
Im glad you got it fixed!!!
