brake lights
Old May 29, 2005 | 09:46 PM
lutherconine's Avatar
Default brake lights
I just purchased a 1990 240
now, the brake lights will not work, fuse was blown
any ideas, all bulbs are good
Old May 30, 2005 | 01:25 AM
Default RE: brake lights
Make sure the Fuse box is very clean and try again.If it blows again the I would look at the switch first if that is fine then look at the printed circuit board for the taillights.
Old May 30, 2005 | 03:46 AM
i will try the switch
do i need to sand the fuse holders
all the other lights work.
tail, turn, reverse
Old May 30, 2005 | 01:21 PM
Clean it up any ways and put some dielectric grease on the connections.
Check for power to the switch.Then check the other side with the pedal pushed down.
Old May 31, 2005 | 08:51 PM
Alex18's Avatar
Yes check the switch at the brake pedal assmb. I've personally had to fix mine on my junk Honda several times (Volvo does have a superior design) But the switch can always go bad, that sometimes happens. I agree check the fuse also to verify that it does indeed have a good connection.
Old Jun 7, 2005 | 11:48 PM
Thanks for your help, it was the brake light switch
and i repalced all the fuse's
Old Jun 8, 2005 | 02:08 AM
Im glad you got it fixed!!!
aznyaz
Jan 9, 2015 02:38 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
