brand new 1980 245 wont start - again
I just traded a running 67 ford f-100 for a nice looking, yellow, 1980volvo 240 wagon. It had been sitting for close to a year. I got it started, it ran for an afternoon, then quit. I traced it to the main (external) fuel pump, replaced it and the filter. It has run nicely for a day and a half and now it wont start again. I did not have time this morning to open the fuel line to trace where the fuel is or is not getting to, but it sounds like no gas is getting to the engine. This time, however, I can hear the main pump working.
Can a pump getcloggedand be cleaned? Can old fuel really create this much of a problem? Should I drain the tank? What other surprises might await me on a car that has been sitting this long? |
RE: brand new 1980 245 wont start - again
replaced it and the filter Remove the tank sender unit and the filter is on the end of the pick-up. |
Does it have gas?
NM wagon,
Check the relay! Sometimes they stick intermitantly. Poorman |
Thanks for the responses. Does it have gas;)? Yes and no. I found the problem. It was the hose connecting the in tank pump to the sender unit. There was none. It was totally deteriorated. So the main pump was working on its own until the fuel got too low. I think the intank pump has been working all along based on the sound.It starts immediately now. In the morning, however, it needs to run a bit before I hit the accelerator or it will die. Also, occationally during the day, I will need to give it a little gas to get it to turn over while cranking. By the way, how is it that cars with in tank pumps can safely get electricity to the terminals of the pump? I suppose that while the terminals are submerged in fuel, its no big deal, but when the terminals are exposed to vapor...yikes! there must be some safety design that I'm not seeing.
