brand new 1980 245 wont start - again
Old Aug 17, 2007 | 01:14 PM
nmwagon's Avatar
Default brand new 1980 245 wont start - again
I just traded a running 67 ford f-100 for a nice looking, yellow, 1980volvo 240 wagon. It had been sitting for close to a year. I got it started, it ran for an afternoon, then quit. I traced it to the main (external) fuel pump, replaced it and the filter. It has run nicely for a day and a half and now it wont start again. I did not have time this morning to open the fuel line to trace where the fuel is or is not getting to, but it sounds like no gas is getting to the engine. This time, however, I can hear the main pump working.
Can a pump getcloggedand be cleaned? Can old fuel really create this much of a problem? Should I drain the tank? What other surprises might await me on a car that has been sitting this long?
Old Aug 18, 2007 | 12:41 PM
billofdurham's Avatar
Default RE: brand new 1980 245 wont start - again
Assume this was the main filter. There is another on the pick-up pipe inside the tank which should be cleaned every 15,000 miles. Needless to say, because of where it is, it usually gets overlooked.
Remove the tank sender unit and the filter is on the end of the pick-up.
Old Aug 20, 2007 | 07:59 PM
volvo 4 life's Avatar
Does it have gas?
Old Aug 20, 2007 | 09:05 PM
poorman's Avatar
NM wagon,
Check the relay! Sometimes they stick intermitantly.
Poorman
Old Aug 20, 2007 | 10:55 PM
nmwagon's Avatar
Thanks for the responses. Does it have gas? Yes and no. I found the problem. It was the hose connecting the in tank pump to the sender unit. There was none. It was totally deteriorated. So the main pump was working on its own until the fuel got too low. I think the intank pump has been working all along based on the sound.It starts immediately now. In the morning, however, it needs to run a bit before I hit the accelerator or it will die. Also, occationally during the day, I will need to give it a little gas to get it to turn over while cranking. By the way, how is it that cars with in tank pumps can safely get electricity to the terminals of the pump? I suppose that while the terminals are submerged in fuel, its no big deal, but when the terminals are exposed to vapor...yikes! there must be some safety design that I'm not seeing.
Friend
Dec 1, 2013 10:06 AM
crad159
Feb 22, 2009 04:56 PM
crystalfleet
Jan 16, 2008 07:30 PM
nmwagon
Aug 17, 2007 11:04 PM
sick93lx
Jul 19, 2007 11:31 PM
