A/C Delete
Old Mar 23, 2006 | 02:44 AM
dmelvi007's Avatar
Default A/C Delete
I know that IPD has an A/C delete kit for the B23F, but does anyone know how to bypass the compressor on a B230F?
Old Mar 23, 2006 | 10:44 PM
Default RE: A/C Delete
Depends on which Model you have. Some you can just run the steering belt to the water pump.
Old Mar 23, 2006 | 11:09 PM
dmelvi007's Avatar
Nope, try again.
Old Mar 23, 2006 | 11:31 PM
We have done a couple from the steering to the water pump and others from the crank to the steering pump on the 240's.
But after a little bit of time they had thrown a belt.
Why not buy a Clutch for the compressor from the Junk yard and install?
Your clutch bearing is seized up?
Old Mar 30, 2006 | 12:12 AM
dmelvi007's Avatar
Do you know what size belt to use when running off of the crank? Also what about getting rid of the compressor and getting the bracket from a car that never had a/c and dropping the power steering pump down? Just think about different ideas.
Old Mar 30, 2006 | 12:20 AM
Not sure of the belt size sorry.
I know here in FLA. you would not be able to find a car without A/C.
But you might be able to fabricate brackets and make it work.
Old Mar 30, 2006 | 07:23 PM
wojeepster's Avatar
on my son's car we used spacers and longer bolts to move the power steering pump forward. worked and was cheap.
VJZ
Jun 22, 2009 08:41 AM
Eple
Aug 30, 2008 04:31 PM
tfolkner
Mar 7, 2008 12:12 AM
bigdaddyrdpjr
Dec 5, 2007 09:43 AM
tupapison
Feb 21, 2006 07:17 PM
