a/c dripping onto interior carpets!
Old Aug 20, 2005 | 10:24 PM
elballoonrat's Avatar
Default a/c dripping onto interior carpets!
i just purchase dmy 1994 940 non turbo.
on the passenger side today my carpeting became drenched, what seams to be happening is on the condenser under the passenger side the condensation is puddling on the under dash cover, then when i go around a turn it falls onto the passengers feet as they reply with a shreeking howl from how cold it is.
i searched the forums, i didnt find any topics that looked to be of this subject, anyone have a similar problem? i thought my drain might be plugged but today i couldn't seem to find a drain line for the condenser.
also, my sunroof is opening but not closing. this is probably a common problem as it is in other cars so i will search that topic right now.
also, does this forum have a certain pciture hosting site it prefers. i'd like to post some pics of my car and some of the stuff ive done to it.
thanks all-Tim-new proud volvo owner.
Old Aug 20, 2005 | 10:56 PM
Default RE: a/c dripping onto interior carpets!
The drain is either in the firewall under the hood where the A/C lines come out or it is under the car.
For the sunroof most likely the switch needs to bew cleaned.Then if that doesn't fix it I would try a new one.
The Site I use is Photobucket.com
Old Aug 20, 2005 | 11:45 PM
Carbuff's Avatar
ORIGINAL: tech
For the sunroof most likely the switch needs to be cleaned.Then if that doesn't fix it I would try a new one.
Lots of good info here Brickboard FAQs
For the sunroof switch specifically
Sunroof Switch
Have fun...hours of reading awaits you!
HTH
redbottle
Jul 18, 2010 09:26 PM
dman777
Nov 26, 2009 06:42 PM
dcjcdc
Jun 4, 2007 07:30 AM
pdubu
Mar 7, 2006 08:56 PM
mexyjarmer
Feb 15, 2006 12:40 PM
