A/C Low pressure port location?
1988 Volvo 240 GL. I cannot find the location of the low pressure port. I have heard it is behind the MAF sensor, but I cant seem to find that either. My haynes manual doesnt show many pictures or describe where the location is.
Thanks in advance. |
If i remember right on a 240 it is on the back of the a/c compressor. Not easy to get to.
Originally Posted by olsoncor
(Post 261528)
I'm not sure if that is a port or not on the receiver/dryer, but, in any case, it would be on the high side of the system and a bad idea to charge through it. I've pretty much decided that A/C is *not* what Volvo does best....
Originally Posted by Joseph/TX
(Post 263466)
You may or may not have a port on the R/D but if you do you can attach a gauge set and verify if you have freon in the system. If it is empty it won't matter which port you check because you have a bigger problem then just topping off the freon. If there is freon in the system and it just needs a charge then your best bet would be to use the suction port on the compressor. There are fittings that allow you to do this. |
