Car shakes side to side
Old Nov 11, 2012 | 04:09 PM
91-740Turbo's Avatar
Default Car shakes side to side
Hey all, the rear end of my '91 740 sedan is shaking from side to side upon braking or acceleration between 10-25 mph. I have checked the bearings, rims, weights, tires, and drive shaft. The only things that my father can think of is that a brake pad is sticking on one or both sides or a disc brake is warped. The discs seem straight. Any ideas?
Old Nov 11, 2012 | 04:36 PM
sure one of the rims isn't bent? I think I'd jack up the rear and with the car in neutral, spin each rear wheel, using a pencil or something held against a stationary stand as a guide to see if there's more than a MM or so of side to side motion at the permieter of the rim as the wheel turns
bad panhard rod bushings would make any side to side motion much worse, so I'd check those (thats the transverse rod that goes from one side of the rear axle to the frame on the other side). with the car on the ground, if you push the back side to side, do you hear or feel any clunking?
Old Nov 11, 2012 | 05:48 PM
swiftjustice44's Avatar
Adding to what Pierce mentions...the simplest thing is bent rims or a broken belt in a tire. So...if an issue isn't obvious, swap the tires front to back and drive it. If the sensation changes or goes away, you've found your culprit.
Old Nov 11, 2012 | 06:15 PM
bent rims can really trash your suspension too. your ball joints and bushings are getting hammered at wheel rotational speed.
Old Nov 12, 2012 | 02:23 PM
I have check the rims, and they are not bent or warped.
AnEskimo
May 15, 2011 12:29 PM
CyDetrakD
Feb 22, 2011 05:08 AM
ibpitty
May 11, 2009 09:36 PM
morrobaybum
Apr 6, 2009 06:43 PM
jonnycd
Dec 26, 2006 09:39 AM
