Changing Transmission fluid
I want to change the fluid in my transmission and I am wondering should I, Or can I, drain the torque converter too?
RE: Changing Transmission fluid
ORIGINAL: Buck I want to change the fluid in my transmission and I am wondering should I, Or can I, drain the torque converter too? Tranny Flush Procedure That way you get EVERYTHING replaced. It's easy! (But it's heplful to have a helper...one person mans the drain hose, the other adds fluid through the dipstick hole. The goal is NEVER to let it run dry) Have Fun (& use a big container, you will get 10 12 quarts) |
