Charging problems.
Charging problems.
Helloooo, so I have a 1985 Volvo 240 that has not been charging the battery properly. I had a warranty on my alternator and was able to replace it but it hasn’t changed the fact that the battery keeps dying. Also the last alternator wasn’t even a year old. I’m not well versed enough to figure out what else it could be. Anyone have any ideas on what the problem might be?
please do these steps exactly in order, and report the results of each question/test.,
1) take a volt meter, measure the DC voltage at the battery before starting the engine, it should be about 12.6V for a fully charged battery thats sat at least an hour after being taken off a charger.
2) turn on the ignition without starting the engine.... does the 'BATT' (or 'ALT') light on the dashboard light up? this light is an integral part of the D+ circuit that 'tickles' or 'bootstraps' the alternator.
3) with the ignition still on, measure the voltage from the small red wire on the back of the alternator to engine block ground (the aluminum rail with the ground screws near the fuel injection), you should see around 5-9V with it connected to the alternator, or 12V with it disconnected. this skinny red wire is the D+ circuit from that dashboard BATT light.
4) now start the engine, does the BATT light go out completely ?
5) with the engine running, measure that voltage at the battery again, it should be at least 1.2V higher than the first reading, eg 13.8V, maybe even 14.4V ... it probably isn't since you're not charging....
6) now, put one probe of your volt meter on the side of the alternator, scratch off any oxidation if needed, and put the other probe on the NEGATIVE terminal of the battery, you should see close to zero volts. if you see most of 12V, your alternator ground is bad.
'how to fix' depends on 'why its not working'. those tests I detail above will pin this down.
in general, there's several failure modes.
1) the alternator itself is completely worn out, this requires a new alternator
2) the alternator brushes are worn out, you can replace the regulator assembly quite cheaply, but if the commutator inside is deeply worn, see 1)
3) the D+ circuit is not working
4) the alternator ground is bad
"rebuilt" alternators are all over the place quality wise. many places just clean them up, slap on new brushes, do a very cursory test and ship them.
ok, hmm, I've been running around for years with that 5-9V number in my head, I think from my old VWs... I just checked my 1993 Mercedes 300CE, which has a similar alternator circuit, it was about 2V. I no longer have a volvo handy to check.
whats actually /important/ is that there's current, and its not 0V and not close to 12V when connected and ignition on without starting. this D+ current provides the 'bootstrap' magnetic field to the alternator, once the alteernator starts to make juice, it provides its own field current.
what vacuum hose leans out the mixture? the one on the fuel pressure regulator ? if anything, pulling that would richen the mixture, as the vacuum causes teh fuel pressure to drop. there's enough dynamic range in the lambda system that it can probably compensate for that via adjusting the injector duty cycle
AnEskimo
05-08-2010 09:49 AM
