Clunking Sound After New Boge Shocks Installed
Old Jun 21, 2006 | 11:12 PM
jdbs3's Avatar
Default Clunking Sound After New Boge Shocks Installed
1990 240 DL sedan. My mechanic just installed new rear shocks (Boge Turbo).
Now when I ride over a sewer cover that is not even with the road, I hear a loud clunk. It happens on both sides of the car.
If the sewer cover is even with the road pavement, then I just hear the normal sound.
Any ideas on what is causing this? Will it go away as the shocks are broken in, or ???
Old Jun 21, 2006 | 11:39 PM
Default RE: Clunking Sound After New Boge Shocks Installed
You need to make sure they reinstalled the Spacers for the shocks.
Old Jul 2, 2006 | 04:01 PM
jdbs3's Avatar
RE: (Tech) You need to make sure they reinstalled the Spacers for the shocks.
I looked at the shocks as best I could; will have the car at the mechanics this week. A bolt goes through each end of the shock. Does the spacer keep the shock end from moving back and forth on the bolt,
or up and down because the bolt diameter does not completely fill the space it goes through on the end of the shock.
thanks
Old Jul 3, 2006 | 01:06 AM
It is supposed to stop the shock from sliding back and forth.
The Bolt should fill most of the hole.
rcrouse2
May 4, 2012 08:08 AM
louis_r2
Jul 9, 2011 11:08 AM
silveruser
Apr 25, 2011 06:07 PM
untouchable
Oct 13, 2009 09:27 PM
dman777
Jan 15, 2008 01:03 PM
