Code 1-1-3 "Fuel injectors"
Old Dec 3, 2009 | 07:41 PM
RED MOFO's Avatar
Default Code 1-1-3 "Fuel injectors"
This was the only code stored on my 90 740T,
Website says a code 1-1-3 is "Fuel injectors"
The connectors are all tight and clean, the injectors are originals...Does the code mean to replace them all, or ?
Who has good rebuilt units?
Old Dec 22, 2009 | 05:11 AM
Typhoon's Avatar
TO answer your question in a non spam way, the code simply means there is an issue with the fuel injectors, the ECU is having to hold teh injectors open too long compared to normal or the current/load the ECU sees in the wiring running to them.
So a likely possibility is blocked injectors causing the ECU to increase duty cycle (time they are open) to too great a value and the ECU recording this issue.
I'd probably either buy new injectors or have yours cleaned.
Regards, Andrew.
Ripkord
Dec 28, 2018 08:28 AM
pinegrovedave
Apr 21, 2014 01:44 PM
Vmax
Apr 7, 2014 07:45 PM
Vmax
Apr 7, 2014 07:42 PM
Platinum52
Apr 17, 2008 06:10 AM
