Shifted into reverse while driving -eeeek
Old Dec 20, 2009 | 11:56 PM
k's Avatar
k
Default deleted
deleted
Old Dec 21, 2009 | 05:16 AM
Typhoon's Avatar
First off, if your shifter is properly adjusted, you should not be able to knock it into reverse. It should have a positive detent that you can't force the shift lever past without pushing the button. You should rectify this.
It sounds like you got away with it, although don't be too surprised if reverse dies very prematurely, you've used up it's nine lives and probably worn a hell of a lot of friction material off that clutch pack and maybe glazed that pack up.
I would not hesitate to flush the fluid and pull the pan to also clean the filter screen.
Regards, Andrew.
Old Dec 22, 2009 | 05:11 AM
tedv's Avatar
I wouldn't do anything about it, other than change the fluid. And learn a lesson. When it goes, it goes!
ga11sport
Dec 30, 2012 01:25 PM
boostnm3
Dec 16, 2010 09:47 AM
rspi
Apr 3, 2010 06:12 PM
Mike Hasson
Jul 20, 2009 09:14 AM
syncan
Jul 9, 2006 12:50 AM
