Dash bulb indicator light on.
Does this mean that a light is out? or the bulb relay is out?
Sometimes it is on all the time, and at other times it's only out when I hit the brakes. I do know that one of the bulbs is held onto the circuit board with DUCT tape!!!! Part of the holder broke and that was the previous owners solution.
I'm just wondering if I actually make the a good connection to the circuit board and get a good bulb in that spot, will the issue resolve or is something else going on? Or am I going to need to do some testing?
So some more information. I still don't know what the heck is going on.
The right rear taillights do not work when the headlights are on. And the bulb indicator is always on when the headlights are on.
Turn the headlights off and the bulb indicator also shuts off. but it comes on when I push on the brakes. As far as I can tell all the other lights on the car work.
I have the same problem. One of the bayonets on my left brake/taillight is broken off so I occasionally have to go in the back and mess with it a little until it works. I've found SOME new bulb sockets online and on ebay, but they're not by the piece, so I'm not sure what i'll get. It's hard to line that bulb up the right way to make it work with a bayonet missing!
The only lights that aren't working are the reverse lights (white), but I'm not too worried about those for the moment.
The indicator light is still lit if I hit the brakes or turn the headlights on. Not sure what's going on there, but I can live with it being on. I might just remove the bulb in the dash now that I know everything is working. What's that light supposed to be warning me about anyway?
the light is supposed to warn you that you have a bad bulb. but it also comes on if the wiring is funky, if the bulbs are mismatched, etc.
do always use the chrome base euro style tail light bulbs in Volvos, the brass base cheap kind will corrode in the sockets. I can usually find the chrome ones in the big brand auto parts chains hanging on the Sylvania racks with the dark green "OEM" cards. or get them at a proper euro (vw, volvo, etc) parts place.
Hey pierce. Me again. Can't seem to let go of my son's 1990 740 GL. Maybe because it's still running fine even after getting plowed so hard from the rear by a SUV it bent the frame rails. Basically got accordionated. Rear doors open not at all, front doors open and shut with only moderate yanks/shoulder rams. Trunk still closes fine, though. Not well, but fine. No leaks filling up either! Anyway back to the bulb warning light...
Like zloetakoe, my warning light only goes off when I pump the brakes. Sometimes it will merely flicker briefly when pumping brakes. Sometimes it will remain out after pumping, only to come on again with the next pump. Most of the time it will flicker in sync with the left signal light (not the right one, though). Of course all bulbs, including brake light bulbs, are fine. Well... they are now, anyway...
When I pulled the old girl out of the ex's garage (it sat there for about five months after the accident) and tried to get it back to my place, it got about two miles before it started faltering. After playing around a bit (and discovering an O2 sensor code, which I cleared; it hasn't returned), I noticed the left headlight (facing car) was half-strength. Bulb looked fine when I checked it, however. I then found that I could kill the idle by switching on the high beams (to be precise, the car stalled at the moment I turned on high beams; maybe coincidence?). To get the car the rest of the way back without risking faltering again, I unplugged the headlight. Today I plugged it back in to try to get it to fail the same way again. I couldn't, though the left headlight was still at half-strength; also noticed that corner marker light was half-strength too. Until suddenly, both headlight and marker light were fine. And they haven't dipped since, even after multiple startups.
Hoping you didn't have to read to the end before figuring out wtf is going on here. Specifically, whether "the wiring is funky" here and how. (Bad contact? Bad ground? Short? Bad alternator?)
Thanks as always.
Thanks as always.
Thanks as always.
Thanks as always.
For what it's worth, found some helpful info on the 740's rear light assemblies (from familyman90 on this thread on volvoforums.org.uk):
The system is a kludge, works by detecting differences in current between pairs of bulbs to decide when a bulb is out. However, as bulbs age their internal resistance changes and so does the current draw and the difference between an older bulb and a newer one can be enough to trigger it. I had to replace almost every external bulb on my old 740 to get the system to behave itself.
Thanks again everyone
