differential fluid change
Old Jul 29, 2013 | 10:13 PM
brickrunner's Avatar
Default differential fluid change
I would like to know when the differential fluid should be changed. My car is soon going to have 200k miles and it has never been changed. It is one of the few things that perhaps has been overlooked. If it needs to be changed what gear oil should I use, how much of it am I going to need and how do I go about changing it, thanks.
Old Jul 30, 2013 | 12:12 AM
if it isn't leaking, hypoid gear oils last basically forever in a differential.
it uses a couple pints, I believe its SAE 80W90 Hypoid or similar gear oil. there's a drain plug and a fill plug on the back of the differential, they strip very easily. clean off the whole back of it before you pull them so you don't get any dirt inside. you fill it right up til its overflowing out the fill hole.
Old Jul 31, 2013 | 05:50 PM
It is not leaking so I guess I am OK. If it ain't broke don't fix it.
Old Jul 31, 2013 | 06:10 PM
fochs's Avatar
Default true that:
But if you do, always remove the fill plug first before the drain. This also applies to manual transmissions. If the fill plug won't come out, you are s.o.l.
Stratoblaster
Sep 2, 2024 11:18 AM
dads 740 turbo
Nov 13, 2008 12:14 AM
jmana
Jan 12, 2008 11:25 AM
jmano5000
Jul 31, 2007 02:53 PM
petes99xc
Feb 4, 2007 10:08 PM
