Does A/C condensor fan turn on with A/C?
Hi:
Is the fan in front of the condensor supposed to turn on whenever the A/C system is turned on?
On a side note, is there a wire in the engine bay that becomes hot the entire time the A/C system is turned on? I am thinking about wiring a relay to keep the condensor fan running whenever the A/C is turned on, regardless if the compressor is cycling.
Thanks.
Thanks.
Just to close the loop...
The Low Pressure Cut Out switch stays hot the entire time the A/C is turned on via the climate control switch in the cabin. I tapped the fan switch into this LPCO switch and now the auxillary fan turns on with the A/C, no matter what.
Thanks for your help.
Volvo240needshelp
05-11-2011 01:30 AM
