Dropped Sending Unit Float in the Tank. To Leave in or Not to Leave In?
Old Jul 12, 2010 | 09:17 PM
J Dubb's Avatar
Default Dropped Sending Unit Float in the Tank. To Leave in or Not to Leave In?
Hello all. I made the common mistake of dropping the sending unit float in the gas tank when replacing my in tank pump. I’ve tried a back scratcher, clothes hanger, rolling one side of the car up on ramps trying to make it float to one side and I just can’t fish this thing out. Is there any danger in just replacing it and leaving the old one in the tank? I don’t mind just buying another one and just being really careful next time. What do you think? Thanks.
Old Jul 12, 2010 | 11:53 PM
swiftjustice44's Avatar
well, I've found worse in tanks...
Old Jul 13, 2010 | 01:06 AM
joshofalltrades's Avatar
i can't see any damage it would do. its shape couldn't allow it to clog up the pump inlet or cause any other issues, so if its that much of a PITA to remove, just leave it.
Old Jul 13, 2010 | 01:25 AM
volvoguy2323's Avatar
Banned
LEAVE IT...Go get another float and install it..happens all the time...don't sweat it bro..common rookie mistake
Old Jul 13, 2010 | 08:00 PM
tedv's Avatar
Yeah, I am sure shops can tell you a ton of stories of what some mechanics ended up dropping in there... No extra charge!
Old Jul 14, 2010 | 10:06 AM
bubba240's Avatar
I was able to get mine out with bent wire and a piece of window screen ... basically a little fish net.
Old Jul 14, 2010 | 06:13 PM
That would drive me nuts. Is it just the ball or does it have the wire arm attached to it? If it has the arm it may get caught under the new arm but other than that I would not worry about it.
Old Jul 16, 2010 | 02:38 AM
redbottle's Avatar
I dropped mine in and it's been 7 months now....no problems only on occasions when my tank is full, as I make a turn the ball plays ping pong with the walls of the tank....I am now able to tell how much fuel there is depending on the sound the ball makes...NAAAAHH...
amazon2
Feb 4, 2015 03:33 PM
mk4rida
Jul 9, 2010 01:05 PM
iamnickcarter
Sep 21, 2007 04:20 AM
1982sherman
Feb 11, 2006 03:50 PM
1982sherman
Feb 4, 2006 02:59 AM
