Flame Trap -PCV Oil Separator Box
Old Aug 30, 2008 | 01:16 AM
Forsyth's Avatar
Default Flame Trap -PCV Oil Separator Box
I'm new to volvo, and have been learning alot how to repair and diagnos problems for the future on my 1990 740 GL regina 291,565 mile car, I acquired it with 289,000 miles - it had been maintained fairly well. I recently had distributor cap, rotor, spark plugs, fuel filter replaced. Also, I just replaced the flame trap mostly clogged up and took off and cleaned the TB.
Question 1:
I was wondering b/c ipdusa.com sells PCV Oil Separator Boxis that something that you have to change ever to keep you car going 500,000+ miles
Qustion 2:
the main hose atop the flame trap filter piece is rather short and winds through lot of other hoses, would there be anything potentially wrong with making it longer and routing it over all the pipes for easier cleaning access.
Question 3:
Is there any other items that are common wear that should be checked replaced often?
-Also is there any place I can find diagrams or pictures that explain which lines and hoses are what under my hood. Some looking like they may need replacement soon, but are very thin, long, and somewhat fragile looking.
Thanks in advance
Old Aug 30, 2008 | 02:12 PM
blue goose's Avatar
Default RE: Flame Trap -PCV Oil Separator Box
The oil separator box is a non-wear item. But sometimes they crack from old age. And sometimes they get so clogged up that it's just easier to replace than try and clean out the old one.
A longer, more convenient hose routing, would be OK.
Old Aug 30, 2008 | 02:41 PM
Forsyth's Avatar
Thanks for the info
Old Sep 2, 2008 | 07:34 PM
wojeepster's Avatar
there should be a vacuum hose routing sticker somewhere in your engine compartment, usually on the flat near the hood lock.
Old Nov 6, 2011 | 03:01 PM
timmattscott's Avatar
how do you remove the oil separator box? where are the bolts that hold it on?
Metal Mickey
Feb 6, 2013 06:40 AM
walexa07
May 30, 2011 03:22 AM
sam2010
Aug 6, 2010 01:07 PM
Beardog
Jul 1, 2007 12:46 PM
HotCoil
Mar 20, 2007 07:20 PM
