Major brake problem
Old Nov 5, 2011 | 09:33 AM
shelley71's Avatar
Default Major brake problem
When I lightly brake to slow down, the brake pedal will get lower and lower until my brake failure light came on, but when I release the brake after I stopped and push the pedal hard, it feels fine and the light goes off. I took it to a mechanic and he said it was bad fluid and he flushed the system. It worked fine for a couple of days, but now the problem is worse. Now when I lightly brake, the pedal goes all the way to the floor and the light doesn't come on, but when I brake harder it feels ok. What could cause this?
Old Nov 5, 2011 | 12:42 PM
swiftjustice44's Avatar
Year and model would help immensely. Still, generally what you describe is a failing brake master cylinder. Should you have an 89+ car w/ ABS, it could be issues there...generally the m/c.
Old Nov 5, 2011 | 09:27 PM
shelley71's Avatar
It's a '89 240DL without ABS
Old Nov 5, 2011 | 09:51 PM
OK...sounds very much like the master cylinder has failed. Not sure how comfortable you are w/ your mechanic....but bad brake fluid does not cause what you're describing in normal city driving. Contaminated fluid is most evident under hard, protracted braking.
Old Nov 6, 2011 | 07:22 PM
shelley71's Avatar
Thanks. It was the master cylinder. This was not my usual mechanic that flushed my system and I will never recommend this guy to anyone. My husband replaced the master cylinder and when he bled the system, the fluid was BLACK!!! How can a flushed system have black fluid?
Old Nov 6, 2011 | 09:28 PM
It can't...you were ripped off!
ENDEE666
Jan 13, 2008 03:48 PM
ENDEE666
Dec 6, 2006 03:44 AM
jayad
Dec 28, 2005 01:25 AM
bluejohn
Engine & Internal
Dec 1, 2005 10:47 PM
