Fuel line repair
Old Jul 30, 2009 | 10:45 PM
qstyle's Avatar
Default Fuel line repair
Hi guys,
Ive got a 82 245 wagon with k-jet. Recently while trying to disconnect the fuel line under the car so i could pull the intank pump out, i bent the fuel line producing a small hole. My stepdad says to "flare" it and all that. I need to fix this for obvious reasons but dont know where to start. any help would be appreciated. Should i get another fuel line? How hard is that? Suggestions??
Qstyle
Old Jul 31, 2009 | 10:41 AM
bubba240's Avatar
Which line is it (by location)? There are low pressure return lines which aren;t too bad to "splice", and high pressure lines which should be replaced whole.
Old Jul 31, 2009 | 01:47 PM
qstyle's Avatar
Hi bubba,
When i look down at my intank pump there are 2 lines, 1 hose (right side) slides right off after loosening the clamp. The other (left side) is a compression fitting/hose, this is the line that i followed under the car that hooks up with a metal , im assuming copper line. Actually if your looking down at your intank pump both lines are on the left side but you see what im saying the hose toward the top is on the (right side) and the other is left. Sorry if that sounds confusing. The compression line is the one that i followed under the car, its just a hose that connects to a metal line. I had to get 2 wrenches on the line to prevent it from twisting but i ended up twisting it anyhow and there is a pin hole in the line now.
Matt
Old Jul 31, 2009 | 02:37 PM
bubba240's Avatar
You twisted the metal line (and it has a hole)?
Old Jul 31, 2009 | 06:59 PM
qstyle's Avatar
It got crimped like if you took a straw and bent it , well after i bent it i tried to bend it back and that made a hole.
Old Aug 1, 2009 | 11:43 PM
bubba240's Avatar
Its possible to splice it together with compression fittings ... or maybe pull a used line if you have a salvage yard close by.
luvmyXC90
May 19, 2013 09:32 PM
smithnr
Apr 8, 2013 04:56 PM
CoVoVo
Oct 24, 2012 10:19 PM
lachbus
Apr 23, 2012 01:47 PM
defuse
Aug 3, 2005 09:41 PM
