Headlight/door warning chime staying on
Old Jun 16, 2009 | 07:00 PM
montysano's Avatar
Default Headlight/door warning chime staying on
Hi all,
Last weekend, I put a new blower motor in my son's '83 245. After I was done, everything seemed fine, with one exception: with all the doors closed, if you switch on the headlights, the warning chime sounds. Also, the dome light does not extinguish. So it seems as if the car thinks that a door is open.
Per Bentley, I tested the #31 terminal at the headlight relay. This is a wire that gets grounded when you open a door (and would, I think, energize the chime circuit). Sure enough, it reads continuity to ground. If I disconnect all door switches, it still reads to ground.
Any ideas?
Old Jun 17, 2009 | 02:16 AM
OmegaDC's Avatar
check the grounds and such on the door switch things. A few of them were bad on my 245. some cheap wire, and about 10 minutes later, and they're fine.
Old Jun 22, 2009 | 07:53 AM
alexdelove's Avatar
I just troubleshot a broken wire in my '93 240 driver door at the hinge point. Wires break at all hinge points with time. If you disconnect the switch and it still reads ground at the relay... wire may be broken and touching the chassis for permanent ground. Just some thoughts.
admasters
Oct 2, 2022 07:20 AM
oreng
Jun 4, 2010 05:34 PM
coopbing
Feb 26, 2009 11:23 AM
KaReN 850
Aug 15, 2005 02:05 AM
reg
Jan 21, 2005 09:52 AM
