help
Old Aug 5, 2010 | 11:31 AM
91sedan's Avatar
Default help
91 740 b230f want to convert from regina to bosch ignition do i need whole engine harness from a bosch ign car and ecu or what
thanks
Old Aug 5, 2010 | 03:57 PM
tedv's Avatar
Why? The cost of conversion would be far greater than the savings you may get having the Bosch...
Old Aug 5, 2010 | 10:35 PM
swiftjustice44's Avatar
Are you thinking of going turbo? I can't imagine any other motivation for removing a decent injection system. You'll have to pull the transmission and swap flex plates too as the tooth count is different for the two systems. Of course, if you want to go turbo, you'll want to dump the AW70 and get an AW71.
Old Aug 6, 2010 | 04:11 PM
91sedan's Avatar
want to convert form rex ignition to bosch and use 740 or 940 turbo fuel system if possable
Old Aug 6, 2010 | 04:23 PM
Pretty much what I figured. There's at least one guy who's turbo'd a Regina car on turbobricks. I haven't really read up on the conversion but...if you have more time than money it can be done. Find and read the build thread...I'm sure it's enlightening. If you have some money to put into the car, I'm thinking the guy probably used MSnS rather than convert everything over. If you want to keep the stock turbo computers, I'd recommend getting a complete parts car so you have every thing you need right there.
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
