help. 740 rear light electrical issues.
Old Dec 8, 2013 | 02:29 PM
dottesen31's Avatar
Default help. 740 rear light electrical issues.
I hope someone can help, because this is stumping me. I have an 87 740 with some electrical issues.
My tail lights were working and somehow they shorted out. My running lights, tail lights and brake lights went out; everything except one running light on the back right. My front lights work.
I replaced the connection boards that the lights mount to, I checked all fuses and wiring, had the wiring diagram printed out and used that and.. nothing.
I am totally stumped and hope someone knows some kind of solution.
Old Dec 8, 2013 | 03:48 PM
sedan or wagon? wagons can have issues where the wiring harness goes over the hinge.
I think I'd check for voltage at the various fuses when the corresponding light is supposedly turned on. if there's power at th efuse,s but not in rear, then its likely a wiring problem in between. if there's no power at the fuse, then its more likely upstream in the switches and stuff.
o0xdannyx0o
Sep 10, 2014 01:38 AM
carney071
Jun 16, 2010 05:16 PM
FlyBoyd
May 19, 2010 07:06 AM
wayaway1026
Nov 3, 2008 06:34 PM
dewrat
Sep 28, 2005 07:14 PM
