HELP ME!!!!
Old Dec 20, 2006 | 08:33 PM
B230FT_BABY's Avatar
Default HELP ME!!!!
ok i got a 93 940 turbo wagon (ya baby)... toexplain my problem let me start at the begining...i was getting a rough cold start a while back and the car was running rich. i found that my intake manifold gasket was just about hanging off at 4 cylinder which was giving me a bad vacum leak... explains that problem... so i change it and bolt everything back up and click click vroom!!! no more rough start, but the car held an idle at about 4000 rpm. so i though ok the comp needs to recalibrate so i allowed it to run for a little while and, as i thought, the car idled downbut stalled out... so i started it again and it constantly varied in idle from bout 500rpm to 2500 rpm while getting a ping near my exhaust manifold at the 500's... i towed it to the local european garage whos owner has a volvo ironicly and they told me that my idle air control valve was bad... so i changed it and it still does the same thing... so far i have dropped about $400 and i just want to get my car back on the road... could anyone PLEASE help me???
Old Dec 21, 2006 | 01:55 AM
Default RE: HELP ME!!!!
Is there a chance you swapped the plugs for the idle motor and the TPS?
Also did you mess with the Idle adjustment?
Old Dec 21, 2006 | 11:11 AM
no the only thing that i disconnected was the IAC hose at the manifold and that was only to get to two of the mounting bolts for the manifold....
Old Dec 21, 2006 | 08:57 PM
Maybe another Vaccum leak.
Have you checked for that using Carb cleaner with the engine running?
shop2
May 1, 2011 07:32 AM
lydjan37
Sep 13, 2010 07:11 AM
dennisimo69
Apr 16, 2008 06:38 PM
markjenross
Nov 7, 2007 08:02 PM
denbass
Oct 23, 2007 03:45 PM
