HELP need test for 940 Turbo MAF
Old Jan 22, 2015 | 09:50 PM
240nc's Avatar
Default HELP need test for 940 Turbo MAF
Working on 1994 940 Turbo ... need to know if anyone has the test using volt/ohm meter and what terminals to test at and get what normal readings should be. Any help would be appreciated.
David
Old Jan 22, 2015 | 11:25 PM
there are some test procedures here,
Engine: Fuel Injection
but really, the best test is to swap it with a known good LH2.4 MAF.. turbo and non-turbo use the same 016 MAF...
Old Jan 23, 2015 | 03:21 PM
240nc's Avatar
[QUOTE=pierce;404711]there are some test procedures here,
but really, the best test is to swap it with a known good LH2.4 MAF.. turbo and non-turbo use the same 016 MAF...[/QUOT\
Pierce check your private messages for mine ...
Old Jan 26, 2015 | 10:29 AM
240nc's Avatar
did the check on back connector and have these readings;
Pin 1 checks out as shown in sensor testing
Pin 3 has 1.4 volts and they state it should have 2.3 volts
Money is tight and I hate to guess .. they say if the voltage is anything but 2.3 to swap for another sensor .... mine fails at 1.4 volts ... does this really mean it is causing my hard cold start and rich running condition?
cheesenacho
Apr 24, 2012 06:10 PM
BlazeS70
Sep 1, 2009 09:47 PM
Daviddc114
Mar 25, 2008 05:33 PM
richsid
Mar 25, 2008 01:01 PM
willko1
Dec 13, 2005 01:38 AM
