How to Re-new Trailing Arm Bushings
Old May 16, 2012 | 10:04 AM
chris charles's Avatar
Default How to Re-new Trailing Arm Bushings
changeing trailing arm bushing
Old May 16, 2012 | 10:34 AM
hmmm? are you asking how do you change that bushing?
put the car up on stands. jack up a spring perch a few inches, unbolt the lower shock mount, and put a jack stand under the differential and lower that side so there's no pressure on the spring, then do the other. unbolt the clamps that hold the trailing arms to the differential. unbolt the forward pivot.
now comes the fun part. you need a SERIOUS hydraulic press and a WHOLE lot of bad vocabulary to get the old bushing out of the swing arm.
Old May 16, 2012 | 04:06 PM
craigshensel's Avatar
WOW, I just did my rear trailing arm bushings... We burned them out of there, then worked our tail off to press new ones back in. They were a beast! Are the other 8 bushings in back there just as hard?
Old May 16, 2012 | 04:48 PM
mostly, sigh, yes. I've not done it myself, but the two mechanics I inflicted the job on both told me they used up monthly allotment of swearing in a few hours
I wouldn't bother with the other ones in the back of a 240 unless there's a specific problem. a bad panhard rod bearing would show up as a clunk if you push the back end from side to side.
wait, 8 more? there's two panhard bushings, and 4 torque arm bushings... what else?
Old May 17, 2012 | 01:42 PM
I think the 90 Volvo 240DLhas these:
Trailing Arm Bushings: 4
Track Bar Bushings: 2
Other Arm (not sure the name): 4
I may have my names messed up though...
Old May 17, 2012 | 02:07 PM
ahhhh. there's bushings where the axles are attached to the trailing arms, those are the two I missed.
track bar is what I called the panhard rod. looking at the volvo parts diagrams, they call it the 'cross stay', hah. it keeps the car from swaying from side to side.
the 'other arm' I've always called the torque arms. volvo calls them 'support stay'
Old May 17, 2012 | 04:13 PM
swiftjustice44's Avatar
Not fun...but not near the chore of the rear trailing arms. The first one I attempted resulted in a ruined trailing arm! I highly recommend removing the entire arm from the car, using/finding a 20 ton shop press and a fresh can of PB Blaster.
Old May 17, 2012 | 05:35 PM
imnsho, Kroil > PB Blaster. and actually, for the cheap amongst us, 50% regular red ATF and 50% Acetone is nearly the same as Kroil.
Old May 18, 2012 | 08:41 AM
Nice. I still have some rattling around on the right side. Need to figure out what that is. I drive on a smooth road and it makes noise, little knocking, not loud.
What do you guys think? What could it be?
Old May 18, 2012 | 08:57 AM
I agree, my experience has been better with Kroil...but I buy PB buy the pallet and the distributor can't get a price for Kroil that is remotely competitive.
Nice. I still have some rattling around on the right side. Need to figure out what that is. I drive on a smooth road and it makes noise, little knocking, not loud. What do you guys think? What could it be?
Could be exhaust (either hangers or bad transmission/motor mounts lowering exhaust), bushings, or even a loose shock. Those are the common culprits. We did have a lady come in with a quiet thump thump thump which turned out to be a rattle snake stuck to the inner sidewall of her tire. He was in bad shape...
Old May 18, 2012 | 11:59 AM
try the ATF and Acetone mix. put it in a spray bottle, or even a trigger oiler, carefully labeled.
Chebucto
Mar 24, 2020 06:19 AM
IRMB
Aug 13, 2012 10:40 PM
grigalid
May 6, 2011 12:02 PM
Platinum52
Jul 17, 2009 07:33 PM
fv15
Oct 23, 2006 06:33 PM
