I need Help Badly.
Old Apr 27, 2009 | 07:50 AM
740GLWagon's Avatar
Default I need Help Badly.
Hello I was wondering if anyone could help me. I have a 740 Gl Wagon in very good condition almost 257K on it and still running great! However, when I bought it the power antenna mast was broken so there is just a little piece of the old mast left. Stations still come in but get static from time to time. I noticed that there was a bolt on the end of the mast so i unscrewed it but the mast does not come off and i do not know how to take it off to install the new one. Can anyone help me. The motor still works i just have it disconnected because there is not enough mast to retract or extend the mast out so the motor just runs and runs so i have it disconnected to save the life of the motor. Can anyone help me replace this antenna!
Old Apr 27, 2009 | 04:38 PM
Johnny Mullet's Avatar
I used an aftermarket "universal" solid mast antenna and replaced the motorized one. Open the trunk and behind the material, you will see the plug-in and mounting bolts for the antenna. If you want the motor antenna to work, you need a new mast and someone to install it.
Old Apr 28, 2009 | 07:35 AM
wojeepster's Avatar
you can buy a replacement mast with nylon strip from fcp groton. I think they are about $20
Old Apr 28, 2009 | 07:42 AM
wojeepster's Avatar
found one at ipdusa.com for $15
http://www.ipdusa.com/product.asp?st...hStartRecord=1
Old Apr 28, 2009 | 07:46 PM
drummerdude08's Avatar
the same thing happened to mine, i put in a hidden powered "mastless" antenna in instead. mounted it right behind the molding next to the previous antenna near the window
Old Apr 29, 2009 | 03:20 PM
tedv's Avatar
Installation however is trickier than advertized. I haven't done one yet where I didn't have to disasseble the whole power assembly and fish out some left over broken piece from the old mast but it is not that tough to do-it probably can use a good cleaning anyway after all those years.
Old Apr 30, 2009 | 04:51 AM
Typhoon's Avatar
If you still have some mast sticking out of the aerial nut, you can just grab it with a pair of pliers and yank the remains out. Refitting is simply a matter of feeding teh new nylon strap for teh antenna into the hole and pushing. The antenna mast will self level once you operate the motor, the motor has a torque limiting clutch on it, so the motor just powers on for x amount of time, fully seating the antenna mast.
Regards, Andrew.
Old May 3, 2009 | 10:06 AM
KeysCuda's Avatar
This is the one thing I was able to fix on g/f's car -- check that, hte swapping out of wiper blades was the easiest I've ever done on any vehicle (nicely done, Volvo!)
It got a universal, rubberized replacement antenna ($6) and was able to use the hardware to attach to the stem that remained. Jerry-rigged but it worked, and she once again is cruising with NPR!
VolvoS60Life
Nov 18, 2011 11:19 PM
dmtri07
May 5, 2010 04:11 PM
stjuuv
Mar 9, 2010 03:53 PM
AzNick
Jul 2, 2009 08:44 PM
daver
Nov 23, 2008 09:17 AM
