IAC valve questions
#21
Thanks for the link, I'm suspecting I have some sort of vacuum leak now (I also replaced the flame trap and fiddled with the tube going down to the oil separator in the process).
This is a bit strange: Replaced IAC/flame trap/plugs/wires/cap/rotor/air filter, cleaned TB and intake hose (did not mess with the air sensor, don't have the proper cleaner for it yet), checked/repaired every connection/ground that was obvious.
Air flow sensor says BOSCH, it's an '89 N/A.
My brick now idles rock steady at ~700RPM on start up, after driving it for awhile the idle starts to bounce between 200-1000.
At this point, if you rev the engine to 5-6000, it takes an abnormally long time to return to the (bouncing) idle, and it does so by idling down to ~4000, hesitating there, then ~3000, hesitates again, ~2000, etc.
Hopefully this will help solve the original poster's problem as well (not wanting to threadjack).
#22
Also if the TPS is not adjusted correctly you'll have a problem at idle. Last is the issue with the throttle adjustment screw. So after you check for vacuum leaks then start with the base idle adjustment with the IAC disconnected. Get a new idle adjustment screw at some auto or hardware shop.
My screw is OK, it's a new IAC, the post originator broke his.
I disconnected the IAC plug just now, and it idled steady at 500. I slowly revved it and it idled down to 1000. Goosing the throttle caused it to go back to 500.
A puzzle, but fortunately it's still drivable, and doesn't rev so high as to slam into gear from park.
Appreciate the help, and Merry Christmas!
#23
ah, THAT sounds like your throttle body is gummed up or sticking, and not closing consistently.
pop it off, and hose it down with a solvent/cleaner while manually working the throttle plate open/close. even get in there with a toothbrush and some WD40 or something, and scrub off any deposits and buildup. then make sure the idle position switch consistently clicks just before its fully closed.
#24
Also going to do this Chinese Water Torture (a SeaFoam recipe) - Turbobricks Forums
PS Merry Christmas!
#25
dnarby
01-18-2014 10:42 PM
thekcstud
10-04-2012 11:26 AM
