Hard to start 2000 S40 after tune up and iac valve change.
Old Oct 2, 2012 | 05:32 AM
thekcstud's Avatar
Default Hard to start 2000 S40 after tune up and iac valve change.
My car wouldnt start. I did a full tune up and IAC valve change and now its hard to start (when cold) but runs like a champ when started. I can get it started with a little work but it isnt firing right up. Any feed back will be greatly appreciated. It does have a new air filter, full of gas, and gas treatment in gas. The fuel filter is about 18 months old. When changing the fuel filter do you need to vent the service valve or is that not mandatory?
Old Oct 3, 2012 | 07:36 AM
metallic's Avatar
had the same problem a few years ago turned out the injector seals were perished cheap repair worked fine after
Old Oct 4, 2012 | 09:12 AM
thekcstud's Avatar
Can you please give me some advice on how to replace those? I am having little luck finding anything on how to repair it online.
Thanks.
Old Oct 4, 2012 | 11:26 AM
migbro's Avatar
Originally Posted by thekcstud
Plugs, wires, and ignition coils. Something you must not have done since you assumed its just plugs.
It is just plugs. Coils and plug wires are not maintenance items.
So the result of your "tune up" is your car is now hard to start.
What plugs did you install?
Were the coils and plug wires Volvo OEM or aftermarket?
Cleaner13
Apr 25, 2014 05:46 PM
dnarby
Jan 18, 2014 10:42 PM
lfc2
2001-2013 model year V70
Sep 10, 2012 02:02 PM
harv mushman
Aug 31, 2012 10:36 PM
Delirious
Feb 17, 2009 03:51 PM
