Idle control valve 240SE
Hi all,
I am currently having problem with 240 Volvo, whenever I switch on the Aircond the RPM drops from 850 to 700..I have checked the all the hose to the idle control valve - all ok and I have changed my idle vacuum valve - back to normal but after 3 months it started back. Mechanic advise me to change the idle vacuum valve so I cannot keep changing the valve so I would like to know is there any replacement unit for idle control valve or can I convert to 740 solenoid type. Need help pls send me if there is a diagram that I can refer too.
Thanks
Thanks
RE: Idle control valve 240SE
I don't have any pics. But the switch on the throttle body needs to be adjusted a specific way or it can affect the idle motor circuit.
With your hand roll the throttle wheel with the car off. Listen for a click as soon as you move the wheel the slightest bit.
Try that and let me know.
am12eaz
05-12-2022 10:07 AM
dnarby
01-18-2014 11:42 PM
