I'm about fed up
Old Jul 22, 2010 | 11:36 PM
slicer's Avatar
Default I'm about fed up
Okay. 86 Volvo, 740 GLE Estate.
Here is my problem, No overdrive. it's the automatic btw. I have 1-3 gears, shifts fine, No slips, or anything.
But no overdrive, I checked the fuse, not blown... Didn't know how to check the solenoid, or which one it even was, Because my chiltons book was wrong.
What else to check? Has anyone experienced the same problem as me?
Old Jul 23, 2010 | 12:27 AM
TIPSP's Avatar
Got Boost?
You can check the OD relay. if not, then you can check the wiring.
then move to the overdrive solenoid.
http://www.vcoa.org/700-900-faq/Tran...OverdriveRelay
Old Sep 1, 2019 | 08:55 PM
Josh Jackson's Avatar
Most definitely it would be your overdrive selenoid and if not that after cleaning or replacing then it would be the trans control computer. Additional, if it's an XC90 made in Tennessee then it will have a junk GM trans that should be replaced with the better foreign one. Yes I said better cuz GM doesn't love you anymore sadly.
Old Sep 1, 2019 | 11:49 PM
josh, this is a 9 year old problem.
a 1987 740GLE doesn't have a transmission computer, its purely hydraulic, with a relay triggered solenoid on the side o fthe transmission that enables the 4th gear OD.
a 1987 740 has a made-in-Japan AW7x Aisin-Warner (Toyota) transmission, same one used in several generations of 4 cylinder RWD Toyota pickups.
htoad
Apr 22, 2018 12:07 PM
silvermine
Jul 16, 2015 08:48 AM
martyo4
Apr 21, 2010 07:52 PM
wagoon
Jan 7, 2009 11:46 AM
opeljunkyard
May 25, 2005 02:27 PM
