Jimmy rig the O/D relay?
Old May 30, 2010 | 08:03 PM
Cherry_Pirate's Avatar
Default Jimmy rig the O/D relay?
My O/D gear (on auto 89 240 dl) wont engage. I checked the relay and it's got 2 or 3 burnt spots on it.
Anyhow, I can't get a new on until tomorrow, I was wondering if I put some tinfoil or something in to make the connection whether that would give me my O/D gear for the ride home. Pretty embarrassing riding the right lane at 10 under speed limit while my engine has the years stripped off of it.
Just a thought.
And if you're a newbie to the board, and just got a brick, go right ahead and change all your relays pre-emptively. They're gonna go. Bricks were built to last longer than their relays, apparently (already did the fuel pump relay).
Old May 30, 2010 | 08:41 PM
TURBO 245's Avatar
Unplug the relay,jump terminal 87 white wire (od solenoid) to terminal 15 blue wire.(fuse #11)
Don't use tin foil,use a piece of wire.
Dan
Old May 30, 2010 | 08:54 PM
Excellent, thank you. See if I can find a wire around here (i'm at work)
Old May 31, 2010 | 03:46 AM
This worked just jim dandy. Anyone looking to see if it's the relay or the solenoid should try this to rule out the relay.
Any other relay I should look into on an 89 240 dl with no A/C? 285,000 kms?
Fuel pump and O/D covered now.
Rich Ard
Oct 25, 2010 08:36 PM
Rich Ard
Oct 25, 2010 12:22 PM
kockyhardrockr
Aug 1, 2010 07:42 PM
jimmy123
Mar 26, 2009 09:27 AM
colgate41
Oct 23, 2008 09:10 AM
