Location of fuel pump relay in 1984 240DL
Old Nov 11, 2017 | 05:28 PM
cengelha87's Avatar
Default Location of fuel pump relay in 1984 240DL
Hey everyone, I have a 1984 240DL that has suddenly stopped working after a routine oil/oil filter change. The battery is fine, spark is fine, and air intake is fine. This leads me to assume that it's the fuel system. On this model, there are two fuel pumps, one on the top of the tank and one inline. I can get the inline pump going with a 9V battery, but unable do the same with the tank pump. In troubleshooting, I have disconnected the main fuel in the tank pump and tried to start the car. I don't see any fuel getting pumped out of this pump. This would lead me to believe that it's either the tank pump or the fuel pump relay. Now, I'd like to try to swap out a new relay but am unsure which relay under the dashboard is the pump relay. I see two under the driver's side, four behind the radio, and two near the ride foot of the passenger. I'd really appreciate some guidance on which is the appropriate relay. And very open to any other suspicions or obvious suggestions in my troubleshooting. I'm relatively new to Volvos. Thanks!
Old Nov 13, 2017 | 08:32 AM
act1292's Avatar
This site should lead you through the diagnosis and replacement...
In the Tank - 240 Volvo Tank Pump and Sender
Old Nov 15, 2017 | 03:08 PM
http://www.davebarton.com/pdf/relay_84_240_dash.pdf <= relays for a 1984. its the 216, 217 relays... later LH cars had a single larger relay but these early ones used two seperate relays for this.
Old Nov 15, 2017 | 08:18 PM
cengelha87's Avatar
Default Thanks!
Thanks to both of you! I was unsure if I should be looking at the relays behind the radio or in the passenger foot area. This diagram is VERY helpful.
joker834
Dec 23, 2020 08:56 PM
spidersilva
Aug 17, 2011 07:23 PM
Patdon10
Jul 22, 2007 10:30 AM
madhatter
Dec 7, 2005 06:00 PM
