Is my fuel pump on the way out?
Old 02-10-2009 | 05:37 PM
Sofar.'s Avatar
Default Is my fuel pump on the way out?
It's been whining for while, and my car's been getting harder and harder to start, and now after a bit of hard driving my engine's developed a misfire under load at low R.P.M.s. My particular model has only one fuel pump, outside the tank.
I've never replaced a fuel pump before, is it hard?
Old 02-10-2009 | 06:10 PM
soundmiami's Avatar
In my experience electric motor windings are like light bulbs, when they go, they go, sometimes with little warning. If the motor bearings are going they will make some noises first and that may in turn lead to failure. Either way they don't last forever.
an old fuel filter can also reduce performance.
I believe the '75 is the same up to 1993 which is the pump and filter is an assembly which I've done in half an hour. Actually it takes me longer to get the car jacked up than to get the pump out. Others say they can do it without jacking up the car but they are thin, young and agile.
Old 02-10-2009 | 06:34 PM
Sofar.'s Avatar
I am young and agile but also fat. My model has its fuel filter mounted in the engine compartment, the '75s are actually considerably different than later models.
Old 02-11-2009 | 07:43 PM
fredbyte's Avatar
I replaced the main fuel pump and filter on my 740. It took a long time because the fuel line banjo nuts were a bitch to take off and put on. I also ended up smelling like gasoline, which my wife and dog did not like.
Read my humorous article at www.stepbystepvolvo.com. You might get a chuckle.
Old 02-12-2009 | 09:48 AM
soundmiami's Avatar
great story,very funny and dead on.... and the left hand threaded metric vice grips are an effective counter measure to stubborn fuel pumps.
Old 02-12-2009 | 04:23 PM
Sofar.'s Avatar
Good news and bad news, the misfire was because my sparkplugs were fouled up. Bad news is they don't make fuel pumps for '75s anymore, so I'll have to find a used one.
spidersilva
08-17-2011 07:23 PM
orcutd
09-27-2008 08:13 PM
samadkins29
12-08-2007 04:05 PM
robert213
07-22-2005 09:33 PM
Quick Reply: Is my fuel pump on the way out?
