Need Advice For Aftermarket Radiator Install 740/760 Turbo
I just purchased an aftermarket radiator from ipd and have a few concerns before install.
Specifically all of the brass connections all located at one side of the radiator.
Since the radiator itself is plastic I am worried about over-tightening
How tight should the brass fittings be tightened and is any plumbers tape required?
Also do any of the fittings on the radiator require more tightening or are they factory tightened?
And any other words of advice you may have.
I bought all new hoses, clamps, radiator switch and seal and thermostat that I will install at the same time. I will also do a flush as well.
Thank you so much.
Thank you so much.
You should not have to tighten the large nuts holding the trans oil cooler inside the side tank of the radiator - they generally never leak there
The nuts on the oil cooler lines - may not come easily loose - be careful trying to get them undone, use 2 wrenches, I have seen destroyed oil cooler lines where the nuts (the people using the wrench) twist the lines - maybe have some penetrant (sp) handy if needed.
No plumbers tape needed, they are flare fittings, use two wrenches if possible to prevent movement inside the radiator.
Thank you so much!
yeah, i'd say its *critical* to use two wrenches, preferably 'flare wrenches' which are like a box wrench with an angle offset on the handle and a missing side, so they can be slipped over a pipe. make absolutely sure the fitting thats on the plastic tank does not turn at all, while you tighten the flare nut down on it.
![](https://images-na.ssl-images-amazon.com/images/I/71%2Bj-zC4pLL._AC_SX355_.jpg)
I have installed the new radiator. It is leaking from the brass to plastic connector on the radiator that connects the small hose from the reservoir. It is a connection that the customer is supposed to install-a brass fitting you are supposed to screw into the radiator. It is brass into plastic. I am afraid of over-tightening. I have snugged it but have not applied a lot of force.
https://www.eeuroparts.com/Parts/417...RoCiL0QAvD_BwE
Also, the 2 brass connections for the automatic transmission coolant that come mounted on the radiator are loose. They have 2 male attachments on either side-one screws into the radiator and the other side for your connection. These are loose in the radiator and can be turned by hand. Should these be tightened or should they be left loose?
You should contact your vendor for instructions - to make sure if something breaks while you are doing things that don't normally need to be done - you will still have a parts warranty
