need help - parking gear problems
my car is a 1992 volvo 240, when I drove my car to school this morning I found that I could not put the my car into park and when I tried to put it into park there was a little bit of smoke comming out of the shifter smelled like burned silicon so I put it into neutral and used the e-break to park later when I got out of class I could still start my car, put it in reverse and into drive and get home. When I got home I was able to put my car into park like nothing was wrong but now when I go in reverse there is a wierd rythmic clicking sound that comes from the shifter and I can feel it shaking too
anyone have any ideas what this could be, any suggestions pls? thank you |
RE: need help - parking gear problems
Sounds like new transmission time. I would go to the local junkyard and see if I could find one there. If you can get one, then shop around and find a shop that's willing to put it in. Keep in mind that your whole car can probably be replaced for $1000.
[align=left] [/align] |
Before that I would inspect the shifter assembly. The neutral position switch might be going bad.
Which would also mess with the shiftlock and thats what might be making the noise. |
Hold on! Don't replace that tranny just yet!!
First thing to look at is the neutral safety switch. http://cleanflametrap.com/neutsw.html Next thing to look at is the tranny shift linkage. There are two identical rubber/plastic bushings at the pivot points of the gear selector linkage. The rear one is easy. The front one is hard to access. May have to remove the shift rod. |
