New 240 owner..... tire sizes
Old Jul 23, 2022 | 08:33 PM
240LongRoof's Avatar
Default New 240 owner..... tire sizes
Hello!
I am now a proud owner of a 1991 240 and I was wondering if a 225 55 r16 will fit on the back without any rubbing. It is at stock height. I have 215 55 16s on the back now and they are pretty tight to the rear track arms and are 8.5 and the 225 55s are 8.9. I am looking to have a taller and wider tire in the rear because I am running a 350/Th350 3 speed with no overdrive and 3:73 gears and I am at like 3200rpms at 60mph and If I can get that down to 2900 or 3000 I will feel better about the highway lol.
Cheers,
Shawn
Old Jul 23, 2022 | 08:40 PM
Old Jul 23, 2022 | 10:11 PM
fitting wide tires is also dependent on the rim's offset. a 215 or 225 would need a 7 inch wide rim and for the 240s that should match to an ET15 (factory 6Jx15 or 6Jx16 list as ET20...)
Old Jul 24, 2022 | 04:54 AM
I am running hydras btw
Old Jul 24, 2022 | 10:36 PM
those are 6.5J-16s with a 25ET. I'd probably not go any wider than a 215 on that rim - you can mount up wider but the sidewalls will pull in and that may cause issues down the road. the 25ET means the centerline of the rim is 25mm closer to the car than the face of the wheel hub. Not sure how much clearance you see by the fenders but that's where a new set of rims with a different offset may get a wider tire to fit...
journeyforce
Sep 2, 2021 12:31 AM
ORGramps
Nov 27, 2019 10:11 AM
piv15
Jun 26, 2013 07:07 PM
dezertsub
Jul 27, 2011 10:36 PM
JetTech
Mar 7, 2007 07:30 AM
