New Alternator not charging battery on 1989 240
Old Dec 13, 2016 | 08:52 PM
  #21
Moetheshmoe's Avatar
Originally Posted by pierce
the important dash light to watch for alternator issues is the battery/alternator light.... again, it should come ON when you turn on the ignition, and go OFF when the engine is running. sometimes it will stay on after starting the engine but go out when you blip the throttle, thats OK too, as long as it stays off.
the other lights come on when you turn the ignition on as a ligth test, to verify all the bulbs are good, they too should go out when the engine is running, except as needed to indicate things like OD disabled, or oil pressure low, or whatever.
That's my current problem. They all stay on. So, my new knowledgeable guess is that the isolation diodes on terminal D+ are not allowing current flow back to the lights. Can diodes be changed easily? tested?
Old Dec 13, 2016 | 09:27 PM
  #22
Originally Posted by Moetheshmoe
Thank you very much for the explanation. It kinda makes sense now. Here's an update: I forgot to install all the screws on the rectifier. So reassembled everything and ran the tests. Battery voltage is 12.5. Same at terminal B. Terminal D has 12 v going in and when connected it's 9.3 v. And B to battery and alt ground to battery and battery to chassis ground are all under .01 volts. The car started up and at idle the battery was still showing 12.5. I revved it up and it got to 13.7 and held that. But here's where I'm going crazy again. Yesterday all my dash lights came on and stayed on with no charging. Now, only the check eng, oil and srs lights come on and they all go out after starting. So i did the grounding test with the wire to terminal D and they all came on. I have no idea what's going on. If there was a fuse blown in the instrument cluster they wouldn't have come on. Anything that pops up for you?
all those things after you screwed down your regulator sound correct. sometimes you need to blip the throttle to get the alternator going. my BMW motorcycle is like that, and my 89 Jetta did that from new... if you start it without touching the gas, the alternator might not bootstrap til you blip it, THEN It starts charging.
there's a regulator on the instrument panel circuit board, and a strip fuse. if either of those are bad, it gets sketchy. look at the first few messages in this thread, nichols explains it.
wait, what year/model car is this again? i think we hijacked a thread about a 1989 240.
Old Dec 13, 2016 | 09:48 PM
  #23
My current alternator does charge(13.6 volts) like I said, but the dash lights wont go out. BTW, I did see the reference to the cluster fuse for the 240 but I've looked high and low on this 740 circuit board and can't find it. Regardless, my lights are on so they're grounded.
Old Dec 13, 2016 | 10:29 PM
  #24
what year 740? they changed instrument panels a couple times. the fuse is really a 'fusible link', and its soldered in place. it just looks like a jumper wire.
but, your charging problem si NOT in the instrument panel, if you read D+ = some middle voltage when the key is on, and the engine is off, with everything connected.
if you're not seeing charging voltage at the battery, whats the voltage at the big B+ terminal on the alternator, relative to the ground terminal on the alternator? if thats 13.6+ V and your battery isn't, then its a wiring problem.
Old Dec 13, 2016 | 10:47 PM
  #25
It's a 1991. I think I found it, but had to pull the speedo to see it. I have pics but i try and insert them and it asks for a url. Anyways, both battery and terminal B on the alt are showing 13.6 volts. I just can't see why the lights won't go out?
Old Dec 13, 2016 | 11:23 PM
  #26
you can upload pictures as attachments, or put them on a photo website that allows linking, like I use smugmug, then link to the image. to upload an attachment, go advanced, then manage attachments, yada yada. keep the uploaded pictures around 800-1600 pixels wide (1-2 megapixels), don't upload native 28megapixel images.
Old Dec 14, 2016 | 09:48 AM
  #27
I forgot about using advanced. Thanks. Is this the fuse?
Attached Thumbnails New Alternator not charging battery on 1989 240-100_0657.jpg   New Alternator not charging battery on 1989 240-100_0658.jpg
Old Dec 14, 2016 | 03:23 PM
  #28
that looks like a resistor, 100 ohm (brown black brown), the gold stripe is the tolerance, 5%
according to the greenbook, its on the very top edge, above the right turn signal lamp.
Old Dec 14, 2016 | 07:19 PM
  #29
I think I found where it should be but I've looked at 2 740 clusters and a 940 cluster and there's nothing there but those 2 holes. BTw, I picked up a working 100 amp at Pick n Pull and everything works as its suppose to. If anyone's in the same boat, a Bosch(that's what I got) will replace a Denso no problem. Later ones have a bigger B terminal bolt but the early ones are the same and fit right in, no modifying. Thanks again for your help.
Attached Thumbnails New Alternator not charging battery on 1989 240-100_0661.jpg
Old Dec 14, 2016 | 08:15 PM
  #30
the fuse is the thin section of circuit between those two copper rings, as outlined by the dotted lines. it does not look blown.
the other important bit on the instrument panel is the voltage regulator. but wait, I'm not seeing one on a 1991 740/940 panel, so maybe thats just a 240 thing??
jessealanramsey
Mar 24, 2023 12:39 PM
skaterjon93
Mar 11, 2016 07:57 AM
timster
Jan 20, 2014 05:31 PM
rahman20k
Dec 20, 2013 07:59 PM
Melvin Lindbergh
Jul 20, 2009 10:44 AM
