new member
Old Jul 7, 2007 | 08:27 AM
shaverjeff's Avatar
Default new member
My sister purchased a 740gl and she is having some issues. Aside from a dead battery the car simply will not start. She has had countless mechanics look at it and from what I've seen they've replaced the dist cap/rotor, spark plugs, wires, belts, hoses, batter cables, and oil sensor. I am afraid she is not mechanically inclined and she is being taken advantage of at the dealers. Anyhow she is 1500 miles away in michigan so I can only currently offer advice. I did look at the car briefly during a trip up there and I replaced all the grounds ( I thought it was an ignition issue) But now I believe it to be a fueling issue. Is there a simple way to test these to ensure the fuel filter is not plugged? and that the fuel pump is working correctly. Where is the fuel pump located for these cars? in the gas tank? Can anyone recommend a good parts dealer?
The engine turns over but refuses to fire.
I have never owned a volvo myself but currently I have a classic 900 saab so I can appreciate the swedish engineering.
Thanks in advance
Old Jul 10, 2007 | 10:57 PM
TedH's Avatar
Default RE: new member
when you turn the key but dont turn over the engine you should hear the fuel pump prime, a kinding of a humming noise for a seccond or two if you dont hear that check the fueses and fuel pump itself...if it is priming i you can check pressure with a fuel guage.
Old Jul 10, 2007 | 11:35 PM
VolvoDriver's Avatar
how badly does she need the car, and how much money? i ask because those replacments are tall orders for mechs to charge. tell her to look to forums and hold off the going to mechs, it's probably a simple fix...we'll try tpo help.
try replacing the rpm sensor, check all connectors, and check timing.
Old Jul 11, 2007 | 10:27 AM
white out's Avatar
What city in MI is she in?
Nick
SHBazTBone
Apr 18, 2014 04:25 AM
Obet Zulueta
Mar 24, 2010 09:39 AM
sauer9
Forum Issues
Aug 6, 2009 01:47 PM
richard
Jul 5, 2005 12:53 PM
95.850.GLT
Sep 15, 2004 09:00 PM
