No power to fuel pump...
Old Jul 30, 2014 | 12:46 PM
240driver's Avatar
Question No power to fuel pump...
Hi there,
I've got a 1986 240DL wagon (4cyl, auto trans), and while back it started acting like it was missing really bad (like it was getting fuel for a second, then not, and repeating that). It wouldn't always do it, but then it got to the point where it did, and I knew it wasn't safe to drive anymore, so I parked it. I replaced the fuel filter thinking maybe it was gummed up: didn't fix it. Checked/cleaned all fuses, that didn't do it, and today I just replaced the main fuel pump relay ($55!!) and that didn't fix it. I've taken jumpers to the fuel pump and make it work that way, so it's not the problem. Does anyone know what could be causing this/how to fix it?
Old Jul 30, 2014 | 01:01 PM
dnarby's Avatar
Check the connectors to the fuel pump itself. Mine were corroded and crumbled off when I went to clean it up. Be careful when you do so, when I tried to get the nut off to reattach the wires, the post snapped - I had to replace the pump.
If that's not it, I would start checking wire continuity from the pump back.
Old Jul 30, 2014 | 01:20 PM
your car has /two/ fuel pumps, one in the gas tank, another underneath. they are both powered at the same time, but the one in the fuel tank is on its own fuse (4), which means there's a simple trick for testing them both separately...
remove fuse 4. take a paperclip bent so you can reach from the spring contacts of fuse 6 to fuse 4. fuse 6-10 are *ALWAYS POWERED*, even when the car is switched off. if you jumper from either side of fuse 6 (or 7,8,9,10) to the LEFT contact of fuse 4, you should power the MAIN fuel pump, and hear it run. if you jumper from fuse 6(7,8,9,10) to the RIGHT contact of fuse 4, you should power the in-tank pump, which can be somewhat harder to hear.
replace fuse 4 after completing these tests
the wires to both fuel pumps are yellow red, and they run straight from the fuse panel next to fuse 4 to the corresponding pump.
now, if the fuel pumps DID run in the above test, then put fuse 4 back in, remove the fuel pump relay, and jumper from pin 30 (always-powered) to pin 87/2 (yellow red wire), and this should power the fuel pumps, again, you should hear them.
if that also works, then things are getting a touch more complex. The ECU tells the fuel pump relay to trigger when it sees timing pulses coming from the engine via the ICU. when the engine stops turning over, the pulses stop, and the ECU shuts the pumps off a second later.
Old Jul 30, 2014 | 01:31 PM
240driver's Avatar
Thank you both very much! I'll try the tests, and post the results. I really appreciate the feedback!
Old Jul 30, 2014 | 03:29 PM
240driver's Avatar
Pierce, I performed both tests you suggested and heard nothing from the fuel pump.. :/
Old Jul 30, 2014 | 05:46 PM
then its probably the wiring between the fuse panel and the fuel pumps, since you said you were able to jump power directly at the fuel pump and it ran.
Old Aug 4, 2014 | 04:09 PM
240driver's Avatar
Ok, so ,I've done some more work/testing. I pulled up the carpet and found the wires running to the fuel pump, took em off the pump and pulled em up through the floorboard. My dad and I did continuity tests from the wires at the battery to the ends/connection points. They passed the tests. Does this mean the fuel pump is bad, or could it still be a wiring problem?
Also let me know if I should post pictures/if that'd help.
Old Aug 4, 2014 | 04:15 PM
you earlier said ...
Old Aug 4, 2014 | 04:22 PM
240driver's Avatar
To clear that up: I used a jumper box, so that's 12 volts guaranteed. When I turn the key to the "on" position, I only read about 2.5-3 volts at the connections. How much voltage should be running back there/ is it possible that somehow the fuel pump is gummed up or something and less than 12 volts won't run it?
Old Aug 4, 2014 | 04:28 PM
the fuel pumps are only powered when the motor is actually cranking over, not when the ignition is turned on. there should be 12V across the wires to the pump at the pump when its powered..
Old Aug 4, 2014 | 04:46 PM
240driver's Avatar
Alrighty, went outside, hooked v/o meter up to the connections (after first testing/confirming that the battery itself gave 12 volts ((11.82 specifically))), cranked engine and it read crazy negative numbers (like in the 100s). Switched wires, gave crazy positive numbers (again in the hundreds, and constantly varying). What does this mean?
Thank you so much for your help/patience so far! I can't tell you how much I appreciate it!
Old Aug 4, 2014 | 05:00 PM
11.8 is pretty close to a dead battery, you should put it on a battery charger overnight before doing any more cranking.
If your volt meter is the typical digital volt meter with autoranging scales, you should lock the range down to a 19.99V kind of range so it doesn't bounce wildly, odds are you were seeing 100s of millivolts rather than 100s of volts. while cranking the battery voltage can drop to like 9V even with a fully charged battery as the starter is pulling a huge current load off it.
Old Oct 18, 2024 | 09:32 PM
Marshallturner's Avatar
“if that also works, then things are getting a touch more complex. The ECU tells the fuel pump relay to trigger when it sees timing pulses coming from the engine via the ICU. when the engine stops turning over, the pulses stop, and the ECU shuts the pumps off a second later. “
I have done the tests that you recommended with a power probe, and both worked but when I crank the key, the pumps don’t switch on and neither does the relay. I cracked the fuel line open right at the fuel filter (This is a 1985 turbo wagon so it is right in front of driver seat under hood) and cranked the key and nothing!
I quoted what you talked about because I believe that is my problem. The only thing I need to double check is that the relay is getting power. If it’s not, what do i need to start looking at? This is a brand new relay so I know that it isn’t the problem.
Don’t know if you are still active as this form was 10 years ago.
Old Oct 19, 2024 | 01:44 PM
How about some details on your car? Year make and model? An 85 240 turbo wagon has a very different fuel system than a 85 740.
Old Oct 20, 2024 | 10:00 PM
Hey don’t worry about i’m all good now i finally got my car running. Now i just need to replace every vacuum line possible and get a new oil pressure sensor and rewire it. When i turn the key to two, the oil pressure gauge just goes straight to the right of the gauge so i need to figure out what’s wrong with that….
Old Jan 4, 2025 | 03:50 PM
carloslovevera@gmail.com's Avatar
What was the issue I’m having same issue now where I get no power to the fuse but relay good and I can jump it using the number 6 fuse box
Old Jan 9, 2025 | 08:30 PM
  #17
My Relay plug was broken and one of the plugs was separate from the clusters of plugs that connected to the relay so i just had to find it and plug it in and it worked just fine. Now have a super rough idle and have ripped open the fuel distributor to clean it out and do an air filter and a new gasket for the distributor… hopefully it will run better afterwards.
Old Jan 9, 2025 | 08:36 PM
  #18
Default Thank you so much
I will do that and I also noticed I have no power to the fuse waa that happening to you
Old Jan 9, 2025 | 08:38 PM
  #19
I’m not too sure now i’m pretty sure there wasn’t because of that one plug and i have no clue what that plug was to but i also had my wires backward on the main pump in front of the tire so the in tank pump was just fighting it and making pressure in between the two lol. but I have no clue what the wire went to i just noticed it plugged it in cranked it over started right up.
Old Apr 19, 2025 | 03:35 PM
  #20
saakey's Avatar
Was reading through this old thread and seems like there are some semi-recent posts here... and some folks who have some good insight to starting issues--mine is a 1980 244... my problem is, the car won't stay running. I did the fuse jump and did hear the pump coming on... I can crank the car, is starts for a split second and then immediately dies. Any other thoughts on what it might be--where I should be looking into next? Thanks in advance.
