Odometer problem
Does anyone have some insight to why odometer will work when it's colder out but when it's hot out it doesn't work. I have taken the cluster apart already and didn't see any stripped gears. Everything else works in the cluster. This is on a 79 245.
79 should be purely mechanical - are those the ones where the white plastic gear cracks? (it's been a while)
Originally Posted by hoonk
(Post 515493)
nevermind what i just posted. I took apart the cluster again and did find a Crack in the little white plastic gear. Must of been in a position where I couldn't see it the last time I had it apart. |
