Odometer problem
Old Aug 21, 2022 | 07:29 AM
MrSavage312's Avatar
Default Odometer problem
Does anyone have some insight to why odometer will work when it's colder out but when it's hot out it doesn't work. I have taken the cluster apart already and didn't see any stripped gears. Everything else works in the cluster. This is on a 79 245.
Old Aug 21, 2022 | 09:11 AM
79 should be purely mechanical - are those the ones where the white plastic gear cracks? (it's been a while)
Old Aug 21, 2022 | 11:53 AM
I did find that the little white plastic gears are a common failure for this. Maybe I didn't check them good enough. It's just doesn't make any sense why it would work when's it's colder out but not when it's hot.
nevermind what i just posted. I took apart the cluster again and did find a Crack in the little white plastic gear. Must of been in a position where I couldn't see it the last time I had it apart.
jagtoes
Sep 3, 2022 07:25 PM
volvodriver99
Aug 19, 2019 09:44 PM
enjuaguese
Dec 29, 2015 07:49 PM
Bmxrider07
Jul 2, 2012 12:58 PM
Dads850
Mar 7, 2009 12:26 PM
