oil in air filter duct work
Old Feb 25, 2013 | 04:41 PM
Micklas's Avatar
Default oil in air filter duct work
1993 240, 212,000 mi, manual trans., non turbo. I recently noticed excessive smoke (oil). It happened all of a sudden. Then I noticed an oil leak comming from the left front of the vehicle above the AC compressor. Removed the air cleaner and duct work to get a better view, and found approx. 4 oz. of oil in the duct work. I believe the leak is from a small hole in the duct work, since any lines below it are brake related. My question: Since this is vacuum, how is it possible for motor oil to accumulate there? Possible cause and what to do to fix it.
Old Feb 25, 2013 | 04:50 PM
the plastic duct work isn't actually 'vacuum', vacuum only occurs between the throttle body and the engine.
only way I know of for oil to get into the air path is via the crankcase ventilation.
s40sedan
May 19, 2016 06:44 PM
djackson47
Jun 7, 2012 11:01 PM
herbeapuce
Jul 15, 2011 08:21 AM
shopower
Jan 3, 2011 02:24 PM
vfgilber
Feb 1, 2010 08:58 AM
