Oil flooded cylinders, 0,0,0,60 compression
Hey guys,
I was driving around 40mph and the engine suddenly sunk to idle for 5 seconds then shut off. I haven't been able to get it started since. Each spark plug was drenched in oil, and each tested at 0 compression except the front cylinder, nearest the grille, which test at 60. Is this a head gasket? note: I did not see any coolant in the cylinder mix. 1990 740 GLE |
RE: Oil flooded cylinders, 0,0,0,60 compression
please disregard this message. my other post titled "Engine damage? Timing belt issues B234F" has updated information.
