Other coolant/antifreeze options?
Im ready to flush my coolant system! My nearest Volvo dealer(1 hour away) sells the coolant for $25 per gallon. My local auto parts sells Prestone 50/50 for $10-13. Would Prestone hurt the cooling system in the long run? IF NOT, Is the prestone for flushing any good? Do I use Di water for flush only and only 50/50 mix for refilling coolant? Im a newbie around here sorry.
1988 Volvo 240DL Wagon A/T w/ overdrive
Just be positive you use the standard type of coolant, generally greenish. DO NOT USE DEXCOOL varieties made for newer cars. I call it DeathCool...will cause issues. There's nothing special about Volvo coolant.
Parris CHello Robinson
Sep 12, 2013 05:47 PM
1988, 240, 940, antfreeze, anti, antifreeze, antifreezecoolant, coolant, cooolant, flush, freeze, mixing, prestone, recommended, volvo
