Outer tie rod bolt problem
Old Nov 11, 2007 | 08:53 PM
deeppaul's Avatar
Default Outer tie rod bolt problem
I have been working on a 78 242 for a friend of mine. He loves the car and does not want to part with it. I changed the boot on the tie rods the other day. I noticed on the driver (left) side there was no nut on the outer tie rod. It is the nut that you tighten when you set the alignment. The PO must have removed it for some reason. I have looked for one, but can not find one. Does anyone know what size it is? Are the threads different on the left and right? I know some cars have left handed threads on one side and right on the other. Any help would be great. I could take the tie rod off and take it to the bolt shop, but it would be a lot easier if I had the size and thread count.
Old Nov 11, 2007 | 08:57 PM
Default RE: Outer tie rod bolt problem
Sorry don't have the thread size but the left and right side are the same.
Old Nov 11, 2007 | 09:32 PM
deeppaul's Avatar
Thanks for the fast reply. I will keep checking, if I have to I will just remove the other one and take it down with me.
Old Nov 13, 2007 | 06:05 PM
onryboy's Avatar
ORIGINAL: deeppaul
why run around looking for a nut when you can get it from www.rockauto.com
SPICER Part # 4011209B {Red Label-Service Grade}
Outer
[/align]
$7.64
$0.00
$7.64
[/align]
Wayne
sealer2050
Jun 7, 2013 09:43 PM
codystoltzfus
Sep 19, 2011 08:59 PM
droberts08
Oct 17, 2009 09:09 PM
dads 740 turbo
Oct 17, 2008 12:59 PM
info2x
Sep 3, 2006 12:28 AM
